Originally Posted by Raylar
(Post 3027660)
When we have done BBC intake air flow shots around the intake valve seat where the charge enters the chamber its amazing to find out that about 75-80% of the air charge actually exits over only about 25% of the total valve seat diameter!!
Best Regards, Ray @ Raylar |
Thank You. Most of us old Motor Heads are just here trying to help some of your appreciative individuals steer your engine projects in the right direction with the minimum of expensive learning lessons we've already had.
Good Luck on your build out, with Bobs help and good parts it should be a nice piece! Best Regards, Ray @ Raylar |
(Post 3027848)
| All times are GMT -5. The time now is 08:43 AM. |
