7.4 Mpi
Question. Does anyone know what heads came on a 1999-2000 7.4L MPI (310HP)? Also, what type of cam (specs)? And, how much HP can the stock MPI system support? Looking for a 375-400HP recipe on a budget. I believe the heads should be the L29 vortec style?? Thanks
It has the Vortec heads(large oval). The cam is 206/211 duration @ .050 lift, .480/.483 lift. I've tried building this engine before. They just don't make any power with the stock EFI. I ported the heads, changed cams and reprogrammed the ECM. The boat only gained about 2-3 mph (so maybe 360-370 HP). I replaced the intake with an air gap and Holley carb and picked up another 5 mph.
I have to second what Bobl said. I tried the same with my '98 7.4 MPI and spent a lot of money and a lot of time and very little to show for it.
I saw similar posts warning against it, but I went ahead with it anyhow, thinking there had to be a way to get to 400 hp without a lot of trouble, and it really was a waste of time and money. |
Originally Posted by MILD THUNDER
(Post 3031084)
You could probably find a performance engine for sale here on the board for around $5,000 to $6,000 and sell yours for $2000 to $3000 and you would be money ahead and have more HP.
| All times are GMT -5. The time now is 02:48 AM. |
