-   -   Distributor gear question 454 to 502. (https://www.offshoreonly.com/forums/general-q/223694-distributor-gear-question-454-502-a.html)
ballon78 03-24-2010 12:03 PM
Originally Posted by ballon78 (Post 3074085)
It is dark in color, My old distruitor came from a rollercam factorymercruiser 7.4 so i'm hopping i will be all set. what are your thoughts?
Here is a pic of a cam, that someone took out of there 502 cratemotor...i can only assume mine is the same as wee got motors from same place just a year apart.
http://i39.photobucket.com/albums/e1...hVfBJ-MJpf.jpg
1BIGJIM 03-24-2010 07:42 PM
I have two of the same engines. I just ordered new cams with cast PRESSED on gear and fuel pump lobes.
These are steel camshafts that need gm part #10456413.
If you had a roller cam before you will be fine.
blownjet 468 03-24-2010 10:09 PM
X2!!! IF ya had a factory hyd. roller before, your good to go,
whatever you do, don't go to the parts store and buy a
replacment-cuz I guarantee the "professionals" at pepboys
ain't gonna have a clue, and would give you the wrong part!
the gm roller gear is melonized, aftermarket"auto stores"
probably wouldn't have it anyway.
ballon78 03-25-2010 07:15 AM
I think for insurance i would like to change my gear on my Thunderbolt ingition, I think its a V but not sure. It has a knock sensor mounted on it too. Will the GM 10456413 melonized gear fit the thundebolt V and the IV distribitors? What is the shaft size on the T-V and T-IV distrubitors?
Next...Shold i unplug the knock sensor module, and replace my ignition module so i dont have a rev limiter at 4700, its too low for the 502, coming from my old 330hp 454.
Im 99 percent sure i had a roller but dont know, the parts fieche shows a rollor cam but who knows, Merc does weird things.
here are my numbers
merc ser number OK199057
casting number 10237297
ballon78 03-31-2010 07:08 AM
casting number 10237297[/QUOTE]
This gear stuff is driving me nuts!! Bought a melonized gear from GM and it wouldnt fit with out removing the washer between the gear and distributor tube.
I Just want to know 100% that THUNDERBOLT V IGNITIONS already use a hardened gear so I wont ruin my Brand New motor.
I ended up putting my old gear back on from my 1996 454 gen VI with Thunderbolt V ignition.
Im just still not sure. I have read every thread here and other site and still no FOR SURE answer.
Want to run the new 502 this weekend...
1BIGJIM 03-31-2010 09:43 AM
I spent 15 minutes talking to Bob Mandra yesterday about this.
Call him and he will shed some light on the topic.
I ordered two new cams from him, and he sent me two new gears to go with the cams.
Griff 03-31-2010 10:57 AM
You are making this way too complex.
It doesn't matter whether your 454 was a roller cam or not. Either way, in a Merc engine, it has the same distributor gear.
Just verify with 1800runsnew that the cam in your new engine has a pressed on steel gear.
If so, you are good to go and can run your distributor as is.
ballon78 03-31-2010 11:33 AM
I have called before and they dont know much....they say its the same as what mercruiser uses....They can't give me a gm part number of the cam,or anything. Just tring to cover my bases, i have invested alot of cash and don't want to ruin the motor.
When i peak at the cam gear it look black in color compared to the shiny cam and lobes.
How do i tell the cam gear material just by looking at it?? Is there a way?
1BIGJIM 03-31-2010 12:31 PM
The reason Bob had to send me two new gears was because my original engine was a flat tappet, they do have different gears.
If I wanted to wait two weeks I could have a cam ground and a cast gear pressed on. There is a shortage in the cast gears since Crane when out of business.
Go look at some other sites than 1800.runs.new they advertise what gear you need. Thats the part number I posted.
I will see if I can post a pic of your cam. I have two sitting in my shop from the ones I removed. Its a steel one piece cam, the gear is not a press on.
If you call Bob Mandra he will explain all the different cores and the differences.
ballon78 03-31-2010 01:23 PM
So if the 502 cams you pulled out of the motor are one piece steel, and my old motor was a roller cam motor right from merc, was that also a one piece cam? Are all gm cams/ merc roller cams one piece. That means my gear should work fine that i have on my stock distrubitor.
Called Bob today , he said that if my old motor was a roller motor than im fine........
Its just So many people are telling me different things that i dont know what to do. Seems to me that my stock merc Thunderbolt V gear should work fine if it worked on my gen 6 454 330hp.......
1BIGJIM see if you can get some close up picks of the gear on the cams. Mine looked black in color...was your like that?
