Drive shower hose for Latham steering
I bought the Livorsi hose pictured below, but either I threw away the instructions/template together with the box :picard1: or they were missing.
Both ways, any suggestion/recommendation/copy of the template which you might have is very welcome! The drive is a latest style Bravo XR. I also found this old thread, according to which if I have a L/H prop I should fit the pickup on stbd side, is that correct? But of course I'd like to be sure also about the exact position, before drilling holes... Thanks in advance! http://www.livorsi.com/images/07catalog/DSHL.jpg |
I have the same shower kit but from Latham. I don't have the template anymore, but do know that you are correct. Install it on the starboard side of the cavitation plate for L/H drive and on the port side for R/H drive. The prop helps push the water up the pick-up.
1 Attachment(s)
The outside of my pickup flange (top of cav plate) is about 1/4" from the edge of the plate on the rear and side. I have a R/H prop so mine is on the Left of the cav plate
Thanks for your pic.
Judging by that, the pickup is placed as externally (1) and as far astern (2) as possible. But I suspect that (at least for 2) the position is actually constrained by the piston, in older Bravo style. In the latest Bravos, there is more space to play with (see below). The point is, is the position on older Bravos the optimal one regardless of any constraint, or could a different placement work better in newer Bravos? http://i23.photobucket.com/albums/b3...Sterndrive.jpg |
Help!
Really there isn't anyone who fitted that hose on a new Bravo?.... :eek:
1 Attachment(s)
Originally Posted by mapism
(Post 3040003)
So in my case the back of the pick-up tube hole is about .25" from the back of the cavitation plate, or about as far back as you can go. Latham provided a paper template. Measured twice (or ten times) and drilled once!:drink: I have heard that sometimes drive showers can cause cavitation problems. Seems the further behind the prop you can mount the pick-up, the better. Maybe this is why the Latham kit is designed this way(?). I do know with my 292 I don't have any problems at all with cavitation after installing the kits. I recommend calling Livorsi if you have any specific questions regarding mounting. |
Originally Posted by 4mulafastech
(Post 3040280)
Did the Latham template place it also as "external" on the anticavitation plate as you can go? That's what Ghostrider pic seems to suggest... |
(Post 3040345)
Interesting, thank you.
'Course it does, thank you for taking the time to check!
I guess I'll have to fit mine just a little bit more forward, due to the bracket shape, as you mentioned. Unless it can be easily detached and soldered on the opposite side, but I'm not sure it's worth the hassle. Anyway, other than that, I don't see why there should be any difference in the optimal placement, between the Latham and Livorsi hoses. Many thanks again! :drink: |
You're welcome!:drink: Now drill carefully. As I remember it was a bit nerve racking for me drilling on that thing! lol!
(Post 3040417)
Btw, did you repaint the hole before fitting the pickup, or just used some sealant like silicone, or what else? |
(Post 3040455)
Yeah, I guess so! I'll take it easy, starting with a smaller hole...
(Post 3040455)
Originally Posted by 10K4U
(Post 3085835)
Can you post some pics of your installed drive shower?
But I have the Latham template (thanks again, Kirk!). If you're interested, just pm me your email and I can send it to you. |
1 Attachment(s)
(Post 3085835)
(Post 3087048)
Here is what the Latham drive showers look like installed on my Bravo 1 outdrives.
I have an 03 292 that looks just like yours! It seems as though my drives are getting hot because they are pushing oil out and getting that chalky looking mess on them. I'm trying to solve the issue by putting on some drive showers, I ordered the Simrek Halos and it seems like they aren't going to work with my steering setup. I have the Latham setup on mine. I have been reading about the different types of showers and some people are saying that the shower that's made for the Latham isn't actually effective for cooling the drive. Could you please let me know how well yours is working for you? It seems like that would certainly be the easiest route to take since it just screws right into the top of what's already there. I just don't want to waste the money on something if it isn't going to work. Also, I don't really want to drill the holes in the anticavitation plate if I don't have to. Any info and advice would be greatly appreciated. Thanks
| All times are GMT -5. The time now is 03:45 AM. |
