-   -   Shifter and Throttles (https://www.offshoreonly.com/forums/general-q/224243-shifter-throttles.html)
OhioRiverCigarett 02-09-2010 06:27 PM
I am considering changing from my twin top mounted old combine throttle and shifter to the modern separte shifter and throttles.
The only problem is I don't want to spend 1K. What is the best deal going. What is the difference in the other companies.
getrdunn 02-09-2010 06:35 PM
I just did this. Or am in the process. I found a very nice used set of KK's on the board for around 375.00. I ended up buying some new cables also. The cables are not top of the line however they'll get the job done. It will bring a whole new look and will be much easier to manuver around also. You can typically find a used set for twins for around 400.00 if you keep an eye out and not be in a hurry.
OhioRiverCigarett 02-09-2010 06:59 PM
Good Info
Thanks. Good thought. Not much to go bad or need rebuild. Probably great item to pick up used.
getrdunn 02-09-2010 07:34 PM
I would even look back a ways on the swap or even in classifieds. In some cases guys don't always keep their used items fresh or current. Otherwise put thread out that your looking for a good used set and see what kind of response you get. I'll keep my eyes open also. The ones I got are very nice without hardly a scratch.
Griff 02-10-2010 01:49 AM
Search "Gaffrig" and "Livorsi" on ebay. There are sets on there quite often.
