454lx Mpi-502mpi
Might be switching from a 97 454 LX/MPI (330php-350 crankhp) to a 95 502 MPI,,,, Is this a direct swap, or will I need other parts?
Question how complete is the 502MPI?
Supposed to be a complete take out,,,, not sure on the flywheel and little things, I am pretty sure they are both gen 5 motors, thats why I was hoping it would be pretty cut and dry,,, but I know my luck !!!
Obnoxus,
It's going to be a fun summer watching you and Paul. :D The only bad thing is I’ll be watching from behind you guys this year. :( Dan |
Its a done deal,, I pick it up Sunday,,, The guy bought 572 superchiller blower motors for his 38 Cig !!!! I am actually more excited to see his boat then picking up my motor !!!
Oh,, and you behind us,,, yeah right !!!
UPDATE.....
Ok I bought the motor,,,,, The good news is he gave me a COMPLETE motor,,, all the way to the bellhousing so that is solved!!!! My question now is fuel..... My exsisting motor is a cool fuel setup,,,, the 502 has a vapor seperator can I just drop it in, and all will be fine? Should/can I switch the 502 over to the cool fuel. One last question,,, looking at the book the 95 ( mine ) 502 has a plug gap 0f .035,,,, 96 and newer has .040,,,,, why ? |
the older one has an ignition coil/system Tbolt IV or V which produces not as much spark voltage/energy and so slightly smaller spark gap spec as the newer EFI
ursus,,, thanks ,,, is it worth upgrading to msd or is stock ok,, both years are rated at 415 hp,,,, does the 95 have a rev limiter?
Dennis,
Sounds like a good deal. Now your Baja has been injected with a little Cig. Juice.:p Should really wake it up. Now you can get some real big air at this years poker run. Mark |
| All times are GMT -5. The time now is 01:01 PM. |
