-   -   500 EFI heads-freshen up or replace? (https://www.offshoreonly.com/forums/general-q/224910-500-efi-heads-freshen-up-replace.html)
INDY27 02-21-2010 07:32 AM
I have a pair of 2003 500 EFI's with 2.3 Whipples with about 180 hrs, heads are stock and have no problems yet but the valve springs are probably tired and all the recent ethanol/valve seal issues I am considering reworking or just replacing my heads with aftermarket and then selling the stock ones...any suggestions?
Greenkeeper 02-21-2010 11:25 AM
INdy27,
I just rebuilt mine, magnafluxed, guides, seals, resurfaced, 3 angle valve job @174hrs. We checked the springs and they were still at spec. Did this preventatively while upgrading to Cometics. I think I remember reading that the springs are good for 300 or so hrs. but don't quote me on that. Eddie at Young Performance will know the facts as well as a hand full of the other pros on OSO.
All that said, my engine has been nursed, but if I was reamin er out, would have replaced everything.
I was gonna put alum. heads on but the motor would have had to come out for tuning Eddie said, I did not wanna have to go to that extreme just 4 head gaskets. I the future when she's tired, I will step up to the next level.
offshoredrillin 02-21-2010 12:09 PM
depends on what you want out of it. if you are happy with the performance just redo them the way they are, if you want more then you can go aftermarket. however like said above, once you do that, you have to address some other issues like comp and fuel, start putting in more air and not change the fuel map = boom.
Strip Poker 388 02-22-2010 01:09 AM
also if he rebuilds ,replace the springs,cheap and not worth the chance!!
Im still stock heads.also is ya go beter flowing you will have to turn the blower harder,
INDY27 02-22-2010 01:45 PM
Hey Rob,
You have Mark Boos number handy?
Thx,
Lee
offshoredrillin 02-22-2010 03:48 PM
Originally Posted by INDY27 (Post 3052276)
Hey Rob,
Thx,
Lee
http://www.pmefi.com/
INDY27 02-22-2010 05:55 PM
Originally Posted by offshoredrillin (Post 3052366)
Thanks offshore!
Strip Poker 388 02-22-2010 10:25 PM
Rob your fast,what ya doing over here dude:drink:
Young Performance 02-23-2010 09:15 AM
As Rob (Offshoredrillin) said, it all depends on what you want. If you are happy with the current power output, then just freshen them up. If you are looking for more, then go to aftermarket heads. Just keep in mind that if you go to alum. heads, then there will be some programming to be done. There are a few of us that can do it.
The weakest links in the stock setup are the exhaust valves and the head gaskets. Personally, with the time on them, I would rebuild the heads with new valves, springs, retainers, locks, seals and head gaskets. Use a good set of valves (like Manley), good springs, 10* retainers and locks (instead of the stock 7*) and a set of good head gaskets (Cometic, or similar) This is where you need to make a decision. At this point, the only additional money to go to aftermarket heads is the cost of the bare heads. You are already buying all the hardware anyway. If you decide to go to alum. heads later on, then all the money you spent on hardware for the stock heads is wasted because the alum. heads will take all different hardware. It will basically cost you about $1500 additional to go to alum. at that point. That is why I say you have to make the decision at this point.
Give me a shout if I can help in any way. Thanks
Eddie
offshoredrillin 02-23-2010 10:41 AM
winter, car bus is slow, doin paperwork..etc etc etc...:)
INDY27 02-23-2010 08:11 PM
What kind of car business are you in?
Strip Poker 388 02-23-2010 08:29 PM
Eddie
Eddie what about aftermarket steel heads? how much better are they compared to stock,like the Iron Eagle's etc or should ya go a little more an just get the aluminum heads?
Rob:drink:
Young Performance 02-23-2010 10:08 PM
At that point, I would just buy the alum. If you are dead set on running cast iron (for instance,in a cruiser that will see a ton of salt water hours and doesn't come out the water to be flushed) they will make more power than the stockers. A large part of the increase you will see with the alum. heads is the bump in compression. You can't get that with the Iron Eagles and others. Some of the aftermarket iron heads will make some good power and are a great upgrade to the stockers. I just think that at that point, you should just spend the extra couple hundred to go to alum.
Eddie
Strip Poker 388 02-24-2010 12:19 PM
Im figuring I could get a good set of aluminum heads ,turn down the boost alittle make it easier on the motor and make the same power and save drives better,I still have the opt for a pully change:drink:
INDY27 02-24-2010 02:36 PM
[QUOTE=Strip Poker 388;3054083]Im figuring I could get a good set of aluminum heads ,turn down the boost alittle make it easier on the motor and make the same power and save drives better,I still have the opt for a pully change:drink:[/QU
How many hours have you put on your heads since they were redone? ;)
Strip Poker 388 02-24-2010 03:22 PM
[QUOTE=INDY27;3054180]
Originally Posted by Strip Poker 388 (Post 3054083)
I'm figuring I could get a good set of aluminum heads ,turn down the boost alittle make it easier on the motor and make the same power and save drives better,I still have the opt for a pulley change:drink:[/QU
Since Dec 3rd 2008 none:mad::mad: but it sure is shinny now:drink:The comp 929 were down 7lbs,they will be due next winter.Haven't had any probs, just ck springs and relap in the seats.There a list of the leak down in 08 before I tore down in my 500efi build up thread,wasent to bad.
2007-2008 was 104 hours and thats how long my new Bmax lasted,upper gear set:eek:
I normally pull motors every winter to re polish anyway.
Rob:drink:
JimV 02-24-2010 03:52 PM
The other option is to modify your existing heads for power. If your going to change valves, go with the 2.300 intake. The stock heads have a piss poor grind on both intake and exhaust seats. Leave the exhaust valves at 1.88 and upgrade to a tulip design. 6% increase in airflow. Also there's a substaintual power increase by porting the stock heads. I just finished a 502 vortech upgrade that made well over 850 hp @5700 rpm with the stock heads with 6.5 lbs boost (highly modified)
H2Xmark 02-24-2010 07:51 PM
are you guys seeing the stock iron heads having a problem with the valve seats falling out? by the way nice video jim v. really a cool setup on that eng. package
formula377 02-24-2010 09:27 PM
Strip Poker
Are you saying the Comp 929 springs are down 7lbs with one season of running on them?
I just started a thread on replacing springs on my carbed 500hp. Just trying to figure out the best spring to replace stock springs with original 250 hours in my engine.
Suggestions???
Strip Poker 388 02-24-2010 11:09 PM
Originally Posted by formula377 (Post 3054534)
Strip Poker
Suggestions???
4 seasons,Isky has a upgrade spring also,sorry dont have the #,stock cam put the 929's in it.I run up to 6000rpm also.
Strip Poker 388 02-24-2010 11:10 PM
none here,but Im not melting shet either:drink:
JimV 02-25-2010 07:15 AM
Thanks, once in a while I'll see a seat fall out ,but it's usually caused by detonation or some other problem
