Water flow
Hey guys,
I need some help plumbing all my water lines as this is my first boat with a stern drive. I have a 454 with a TRS drive. The raw water pick up is on the bottom of the hull. I need some sort of diagram. I plan on running a raw water pump and circulating pump if that matters. Thanks! |
what kind of exhaust do you have?
Travis,
I made up a quick diagram, but I guess I can't attach it here. PM me your e-mail, and I'll send it to you. |
Raw water to bottom of circulating pump, circulating pump to T-stat housing, T-stat housing to exh. manifolds... If I remember correctly. There are a TON of pics though... I would search TRS on E-bay classifieds or on here and see what comes up. I'm sure you could have 5-6 pics in a matter of minutes.
Thanks guys. tcelano, I will pm you right now.
Originally Posted by wjb21ndtown
(Post 3054679)
I dont have a power steering pump oil cooler, or trans cooler.
Confirm with Eddie at Young but in a previous post he suggested the 2X8OAL which is our 2X5 bundle length. End caps measure 1.5 inches on each end.
http://www.mrcool.us/catalogsearch/result/?q=205+ee-05 |
Do you have a B/W velvet drive?
Originally Posted by travisluman
(Post 3057210)
| All times are GMT -5. The time now is 10:16 PM. |
