-   -   Maintainence Tidbit (https://www.offshoreonly.com/forums/general-q/22525-maintainence-tidbit.html)
Tinkerer 04-18-2002 09:57 PM
Maintainence Tidbit
If you are having problems with your neumatic (air) cylinders on your silent choice. To lubricate them DONT USE ANY OIL this will make them worse. Use dish soap - PER MERC. TECH.
deboatmon 04-19-2002 05:53 AM
air cylinder lube
Try using performance chain lube from a good bicycle shop. It is wax like in substance to stay on the chain and has characteristics of soap but better. It is designed not to pick up debris. It comes in small plastic squeeze bottles and is easy to store in your tool box.
Good luck.
Budman 04-19-2002 05:09 PM
What part are we lubricating
Can you guys elaborate a little more? Are you talking about lubricating the linkage to the divertors, the divertor pivots themselves, or the pistons within the actuators. The latter is what i am suspecting, but I want to make sure.
Tinkerer 04-19-2002 06:45 PM
The pistons within the neumatic cylinders and you DON'T want to use any oil product as it will only make it worse. Just put some dish soap in the little hole on the side of the cylinder and work it back and forth. Was having a problem with them and tried all kinds of lube -nothing worked - just made it worse. Called and they said to use dish soap...
