looking for a high output alternator for 500 EFI
I am looking for a high output alternator for a 2001 500 EFI. The part # on my current alternator are 19020703-875285.
Anyone know where to find such? Thanks in advance, Allen |
try this http://www.dbelectrical.com/alternators/marinealt.shtml my stock atl. was 55amps it suck when i put msd on.i got the one wire 105amp never had a problem . these guys are good they don t rob you like merc does
Originally Posted by 29scarab10
(Post 3057687)
Anyone know where to find such? Thanks in advance, Allen Ohio Generator http://www.ohiogen.com/ |
More amps requires a bigger wire to the battery
Check with CP Performance. They have one that is well over 100 amps (don't remember the exact amperage). It should be a direct replacement. Call and talk to Mike at ext. 17.
1-800-225-9871 Eddie |
You can take your existing one and get it rebuilt cheaper, add more windings and it is cost effective, many places do it.
I bought one of the hardin marine 130 amp alt. It works good until you put a big load on it at idle. The thing will start smoking. I talked to them and they said it doesn't have enough airflow around it at idle. I wouldn't buy anything bigger than a 100 amp unless you could find a bigger case alt.
Originally Posted by stoltz
(Post 3059014)
(Post 3059014)
| All times are GMT -5. The time now is 11:22 PM. |
