-   -   kiekhaefer shifter cable question (https://www.offshoreonly.com/forums/general-q/226194-kiekhaefer-shifter-cable-question.html)
endeavour32 03-12-2010 08:15 AM
2 Attachment(s)
I'm getting ready to install a set of kiekhaefer shifters in my formula. Right now I have the standard mercury single arm shifter. My question is can I use my old cables? From what I can see it looks likes like the kiekhaefer uses a different cable end. is this the case or am I missing something?
jmrapp 03-12-2010 08:44 AM
You need new cables. They are 33C cables that you need. You will also need a adapter kit for the engine side of the new cables.
Tom flanagan 04-14-2016 06:00 AM
Sorry to bring up an old thread but installing the same setup, did you have any problem putting the cables onto the shifter itself? Seem like I am bending the hell out of my cables
ezstriper 04-14-2016 07:23 AM
I did that swap a while back, used the old cables, just need the end adapters and you are good to go, no I did not have a issue with cables, I think that shifter drops them down as I remember
Tom flanagan 04-14-2016 07:44 AM
I have everything for the engine side and both clevis hooks for the shifter it self but when I put the cables in the groves on the bracket attached to the shifter the ends of the cables are on a angle that does not seem right was not sure if I was missing anything or not. Thanks for the reply!
