-   -   Similarities/differences between 525EFI and 700SCi? (https://www.offshoreonly.com/forums/general-q/226683-similarities-differences-between-525efi-700sci.html)
Stilldouble 03-19-2010 06:11 PM
Except for the obvious, the 700 being supercharged, how much other technical differences are there between these two engines?
The 700SCi specīs
http://i418.photobucket.com/albums/p...ble/700SCi.jpg
The 525EFI specīs
http://i418.photobucket.com/albums/p...ble/525EFI.jpg
Obviously they are both 502 cui, the bore and stroke are the same... but are they using the same block and crank?
The compression ratio is naturally lower on the supercharged engine... (other pistons? rods? thicker gasket?)
The 700ī is using Sequential Fuel Injection versus the MPI fuel system for the EFI...
So, all in all... Has the 700ī "beefier" internal components, such as rods and pistons, other?
Other differences?
Two last questions;
Does anyone know the displacement of the supercharger itself on the 700ī?
Does Mercury manufacture their own superchargers? ...or do they buy them OEM from someone else, such as Whipple or Eaton?
Stilldouble 03-20-2010 04:56 AM
One reason for why I wonder this?
-How much different would a "Whippled" 525 behave compared to a standard 700SCi?
-Same size... roughly the same power...
-How much stronger "entrails" comes with the standard 700SCi? ... compared to a bolt on blower kit from Whipple for the 525?
CB-BLR 03-20-2010 08:37 PM
Same internals on both motors.
Different cams.
Different pistons.
Same heads.
3.3 l supercharger on the 600sci and 700sci.
A 3.3 Whipple kit on a 525 makes around 800hp due mostly to the higher compression of the 525, and the more radical cam in the 525.
Hope this helps,
Chris
laszlo01 03-21-2010 07:15 AM
Cheaper to whipple the 525 EFI and lots more HP in the end.
Stilldouble 03-21-2010 10:34 AM
Thanks for your helpful replys. Is the 3,3 L supercharger used on the 700SCi actually also the same as the Whipple bolt-on kit?
CB-BLR 03-21-2010 10:44 AM
The 700sci supercharger is an exact copy of the Whipple 3.3 supercharger. Dustin did the R&D for these motors.
Chris
Stilldouble 03-21-2010 02:13 PM
This is very interesting!
Many boats found in the classifieds comes with relatively fresh 525EFI:s... Very few comes with the 700SCi... To import one of these boats and then upgrade with the Whipple 3,3L bolt-on kit sounds like a very interesting way to go, if the 525EFI and 700SCi are so similar engines internally. In Europe we run with slightly higher octane, that maybe can compensate some of problems with maybe too high compression with the "whippled" 525???
Still; the compression in the 525EFI is relatively modest at 8,75:1
CB-BLR 03-21-2010 06:48 PM
In my opinion.. being that I have a 600sci.. I think that the 525 with a whipple is a better package than the 700sci. The low 7.5 compression (on the 700sci) makes it more difficult to make power. 8.75 compression is just about perfect for a supercharged motor.
Chris
laszlo01 03-22-2010 08:37 AM
Chris
I agree, I was also told the same thing when i was pricing out A/T's before i found the one I have, I was told to order the 525 boat and then put the money into upgrade down the road versus the 700 package due to cost and performance. If you put the $ difference into the 525 you will have a far superior motor package.
Stilldouble 03-23-2010 07:19 AM
After the whipple update, is there a need for running the engine on the dyno? ...just to make sure it is not running lean, or otherwise missbehaves? ...on the other hand, can the injection (and other related parameters) be fine-tuned under any circumstances, or is it "factory presets" from Whipple only, with no possibility for fine tuning?
laszlo01 03-24-2010 08:54 AM
The whipple kit is bolt on with a initial flash set-up from whipple, you can fine tune it on a PC in the boat with the appropriate software, we are doing a dyno tune since we are doing more of a Kustom application. Talk to Dustin at whipple for the proper application and set-up information, very easy to deal with.
AIR TIME 03-25-2010 03:58 PM
Chris
the compression on my new is 8.4 to 1 it will be a 572 making about 1050 to 1100hp run 93 pump gas is what Dean said. so over sea's with the higher gas you should be fine.
richanton 03-27-2010 03:19 PM
I would have to guess lots of the $$$ difference in the 700 package is in the drives. If you whipple charge the 525s you still have bravos vs. NXTs with the 700s.
Guess it depends how much money you can save going the 535 route.
Stilldouble 03-28-2010 07:20 AM
In this case I am consideringen importing a boat with 525EFI:s and XR drives.
This particular boat responds very well to added power, and the plan was anyway to sell the XR:s and the uppgrade to used SSM #6. The condition on the XRīs is very good, so I will recover some money there.
What I have also heard, and I cannot really verify that this is true (?) The 525EFI is originally using the PCM555 fuel injection, just as the 700 SCi, but with the bolt-on kit from Whipple they are instead using the older MEFI4A injection system (which is a non-sequential system). Some guys sees this as a relatively large disadvantage.
Any comments on this?
