-   -   Spark plugs for a 454 MAG MPI (https://www.offshoreonly.com/forums/general-q/227092-spark-plugs-454-mag-mpi.html)
Hemi Truck 03-25-2010 06:14 PM
What plugs should I be using in a stock 454 MAG MPI. Any help would be appreciated.
P.D.
FIXX 03-25-2010 06:55 PM
Fixx
P.D.
i usually use mr43t..
dbkski 03-26-2010 12:41 AM
Standard: AC MR43T or NGK BR6FS
Projected Nose: AC MR43TS or NGK BPR6FS
Gap = .035-.040"
I use NGK BPR6FS in my 502 MPI. The standard plugs work fine but
I get a little cleaner burn with the projected nose plugs.
n20michael 03-26-2010 01:49 AM
NOT! looking to hijack, but, curious?
Same plugs would work in a 96 454EFI? calls for MR 43T's as "stock" as well. Also, whats the K&N number for the oil filter?
Thanks!
Michael
Griff 03-26-2010 11:58 AM
Thanks!
Michael
Same plugs. Don't know the K&N filter number. Just cross ref it with a Mobil1 M1-302.
PAST DUE 03-26-2010 06:00 PM
NGK YR5 vpower v grove center electrode better idle and more resistant to fouling
n20michael 06-08-2011 11:26 PM
Whats the difference between the NGK YR5's and the NGK BPR6FS'???
Are they interchangeable?
Michael
