help please stereo install
I hope this aint long. I am want to install a second battery, amp and sub-woofer in a donzi 22zx. Right now the radio has power and holds memory. I want to run radio and amp off second battery with perko switch. How do i hook this up, any help greatly appriciatted.
Bryan |
I`m guessing you`ll want to be able to use the radio from either battery or both batteries at once depending on the situation, so I wouldn`t set your system up the way that you`re describing, running only from one battery. Simply connect the perco up to you two batteries the way the instructions will describe and then connect your amp up to the perco too. This gives you the option then of running it from either battery and also using one battery while cruising with the stereo on and switching to the other when you`re stopped & running your stereo from it, that way you`ve always got a good battery to get you home if u over do it with the tunes.
Would you connect the amp to the center post on the perko? or one of the others to isolate?
Thanks |
i would have a battery dedicated to starting, & a battery for your stereo. If the amp can run off both batts, you could run the risk of running down the batts to a point where they dont have enough juice to crank the engine.
I should have worded that better. I just put together a whole new system (opening day of boating here in Seattle) The amp cables are just sitting back there in the corner, I can hook them to the Perko. Or I can hook them to one of the batteries.
What would be the best. I think last year I just had it on the stereo batt, but then you have to remember to lift the seat and isolate once you toss the anchor to kick it. Thanks |
Hook them to the second battery
http://www.atkinsonelectronics.com/list.asp?lt=mar
look at application 3 on the last page of this - http://www.atkinsonelectronics.com/p...s/DBCM-75A.pdf |
Originally Posted by Griff
(Post 3099048)
cool, thanks.
Actually, one more q. What about the stereo turn on wire. Last year mine was hot all the time, perko off or not. I'd kinda like when the perko is OFF, that everything is off. So, does the Yellow go to the perko or the batt? Thanks. |
That's up to you. I have no power to anything when my perko's are off. Keep in mind, you will lose radio presets if the boat sits for a while.
A stereo can also have a very slow drain to the battery over a long period of time. |
| All times are GMT -5. The time now is 11:31 PM. |
