-   -   serial number on engine block.. (https://www.offshoreonly.com/forums/general-q/227493-serial-number-engine-block.html)
nordy racer 03-31-2010 12:21 PM
hey guys.. i own a Baja with a 2006 Mag 496 (375hp) engine.. i need to know where i can track down the serial # so i can order a impeller kit.
thanks,
mike
SDFever 03-31-2010 01:14 PM
thanks,
mike
If it's worn off the engine cover then look on the bottom of the block just above the oil pan on the starboard side in the rear corner. There is a hard to read tag that has probably been painted over.
Boat Tech 03-31-2010 02:06 PM
https://appcenter.mercurymarine.com/...Locator-mc.jsp
mapism 03-31-2010 02:14 PM
Originally Posted by Boat Tech (Post 3078860)
I'm not sure that really helps.
'Dunno about other engines, but in 496 it's just above the oil pan as SDF said, not below as the drawing seems to suggest...
