-   -   Older Gaffrigs (https://www.offshoreonly.com/forums/general-q/227533-older-gaffrigs.html)
MILD THUNDER 04-01-2010 09:36 AM
Older Gaffrigs
The Gaffrig gauges that have the built in warning lights....Did these have a feature that triggered a warning alarm built into them, or did you need separate sender switches to trigger the alarm?
boatnt 04-01-2010 09:42 AM
Same senders,light feature is build into the gauge
MILD THUNDER 04-01-2010 10:27 AM
I guess what i am asking is, to hook up a warning buzzer, is there a terminal on the gauge that will trip the buzzer in the event of a high water, oil temp or low oil psi.
Griff 04-01-2010 11:37 AM
No, the red light is based on the guage reading and there is no terminal to wire an alarm off the guage.
FIXX 04-01-2010 12:37 PM
Fixx
If your looking got a way to trip a buzzar use a coolent fan switch that goes into a coolent passage off of a older fwd car,they trigger around 220 deg, they also make a low oil pressure switch that goes off around 5lbs..
