Thermostat housing
Hey guys i have a gen 5 mercruiser engine, and I am converting to a crossover from the stock water pump. i need a aftermarket thermostat housing. The catch is I also need to be able to put the stock 2 sensors back into the housing. How can I make this work? Thanks again
Hardin marine sells a 1 inch spacer that has 2 holes 3/8 inch in them.. I got one this winter. so far works well.. got the high water temp sensor in one and the temp sensor in the other..
One catch.. since you put a gasket on the intake then the spacer then another gasket then the them housing the spacer is not grounded. so the sensors will not work like that.. I drilled a small hole and thread for a ground wire to attach. |
do u have a link? i cant find it on there website
try here
http://www.hardin-marine.com/detail~ID~1850.aspx the site says the holes are 1/4 inch.. but they are 3/8.. I just got one 2 months ago.. mistake on the site |
| All times are GMT -5. The time now is 11:24 AM. |
