Fuel return regulator
If I have a fuel return regulator and I can not return it back to my tank were is the next best place for it?
Originally Posted by dennis r
(Post 3084443)
How about the fuel filler hose? If you can get to it, you can T the return into it.
Originally Posted by Vinny P
(Post 3084475)
No, he means the filler hose 1&1/4 in hose, go into CP performance and find the fittings you need, I got 2 of them 2 years ago.
(Post 3084475)
I've always returned back into fuel filter housing provided it has another in port.
It is just a bad idea to return to the filter. If you have a small pump on a relatively low hp engine, you can get away with it. As soon as you step up in power and fuel pump, you are asking for trouble. Not only will it heat up the fuel (even with a cooler), but it will continuously aerate the fuel. I will only set one up with a return to the tank. If you can get to the tank at all, then give me a call and I can give you a trick to make a return in the tank. The tank fill hose is another good option. Definitely do not use the vent hose.
Eddie |
| All times are GMT -5. The time now is 09:49 AM. |
