-   -   Bravo 1 stuck (https://www.offshoreonly.com/forums/general-q/228098-bravo-1-stuck.html)
tinman565 04-10-2010 03:29 PM
Bravo 1 stuck
Boat ran great all last season. Winterized...started right up yesterday. Started again this morning, neighbor says "put it in gear"...so forward goes perfect (idleing)...back to neutral...into reverse (perfect)...now it wont come outta reverse !!!! I disconnected the cable to the control lever...no binding. I overode the safety switch, started motor (prop still spinning in reverse), and let everything warm up. No luck. stopped motor, and had wife wiggle shift lever while I wiggled and bumped prop back and forth...nothing. Still stuck in reverse. I never reved it while in gear, and it shifted smoothly from gear to gear till I tried to get it outta reverse. Any Ideas ? Thanks !!!!!!
US1 Fountain 04-10-2010 06:17 PM
Does the cable going to the drive itself move freely, as if not connected on the drive end when you were operating it by hand?
Could pull the drive and check the shifter cable end/assembly
tinman565 04-11-2010 06:57 AM
no...it does not move. Gonna pull the drive right now.
Mr Gadgets 04-11-2010 08:47 AM
Tinman.. see my post is the drive section..
tinman565 04-11-2010 08:32 PM
MR. Gadgets called me and walked me thru the whole problem. Nice guy to deal with !!!! THANK YOU FOR THE HELP SIR !!!!!
