-   -   2.5 offshore 1994 (https://www.offshoreonly.com/forums/general-q/22820-2-5-offshore-1994-a.html)
ski racer 04-23-2002 05:24 AM
2.5 offshore 1994
Hello to everyone at offshoreonly.com
I recently purchase a 1994 2.5 offshore engine for my water ski racing boat all was great until it developed a miss above 4000rpm. Had a look under the cover nothing I could see. Next day tried again wouldn't idle properly or even get the boat off the plane, engine running super rich. Took it to a merc dealer ,mechanical electrical all ok, plugged the DDT into it ,motor running an s3000 ecu (A61) Said I would need a new computer.
Can I rechip the motor?
Does anyone have a copy of the 2.5 offshore chip on their computer I could download? I would be more than happy to send you a copy of my S3000 chip ,Mechanic said the rev limiter had been removed.
Boat has been out of action for 4weeks, Help!:confused:
Gassticks 04-23-2002 07:28 PM
Hey Ski Racer ,
I have two 1994 - 2.5 offshore , But they are carb motors not EFI. If you go online and check out Mercury parts Express they might have what your looking for. Hope this helps you. Good luck!:D :D
ski racer 04-24-2002 04:55 AM
2.5 Offshore
Gassticks,
thanks for your reply. I tried merc express as you suggested but it looks like they could only supply a whole new ecu ,scary price once you double it to get to New Zealand dollars
Cheers
skiracer
NASTY HABIT 04-26-2002 07:20 AM
Ski Racer.... might try the" Scream and Fly " message board alot of those guys are running the merc 2.5s good luck
MERCMAN 05-07-2002 10:46 PM
no problem getting your ecu re programmed but your going to have to send it to the states , its around 50 to 75.00 u.s. dollars. caontact me if you want more info. [email protected]
