Best valve seats?
Bob Teague recently wrote about seat material ideally having a Rockwell hardness #s in the range of 40-50.
I am about to put custom seats into new aluminum heads and come to find out that the big $ copper beryllium seats I bought are pretty soft. Too soft according to the Teague on tech article. Some specifics; Running on 91 pump gas, 10 to 1 compression Stainless 2.35" intakes, Inconel 1.88" exhausts (read heavy) Fuel Injected. closed cooling Heavy spring rates So what is the consensus on the best material? :confused: Eddie? Other experienced Marine engine builders? :rolleyes: BTW the Martin Wells Copper Beryllium seats have a Rockwell hardness of 37 but a wear rating equal to 53. . |
I'm not an engine builder, but I can say that the difference in a Rockwell hardness of 37 - 40 is really nothing. I worked in a heat treat factory for years. Further, if they've engineered the seats to have an impact rating of 37, but a wear rating of 53 I would tend to think that they would seat better and last longer than most seals.
I'm not endorsing anything, but from a metrological standpoint they sound like good seats. |
| All times are GMT -5. The time now is 07:55 PM. |
