496 HO vs Raylar 496 Mag
Would I be crazy to pull my perfectly running 2001 300hr stock 496HO and replace it with a 496Mag with Raylar kit, port work and modified throttle body that is listed in classifieds? Granted I need alot more info than what is listed in the ad but just wondering what everyones "Ray's" thoughts are? Is it worth putting in a motor I know little to nothing about how it was built? http://www.offshoreonly.com/classifi...o33270-en.html
If you want a Raylar kit why not get one put on the motor you already have?
At least you know the history and condition of your motor. |
A few Raylar parts do not a Raylar 525-496 make!
That 496 mag engine is just a customer who bought a Raylar camshaft and rockers for his engine and did some of his head work on his stock iron heads. That engine might make 435HP at best. It's not a Raylar 103 kit that with our aluminum heads, intake, cam, rockers, etc. that makes a 496 HO into a 525HP engine and a Mag the same with our reprogramming on the Mag ecm up to HO spec.
Do a compression test on your 496 engine and if the compression is good and even, upgrade you 496 with the Raylar 103 kit and have 525HP with stock exhaust and 565-570HP with good headers or header manifolds like Dana. Best Regards, Ray @ Raylar |
just put the 103 kits on,,,i already did:drink:
Originally Posted by Dave M
(Post 3090454)
Originally Posted by Raylar
(Post 3090458)
