circ pump to crossover hoses ?
on my 500hp w/ gills i have 4 hoses coming of the stock t/stst housing to my gills 2 go down to the bottom rails on the manifolds and the othe 2 go to the back side upper part of the manifolds they are the 2 that come off the brass peice with the spring loaded check balls in it. my crossover only has 2 outlets so how do i plumb this system.
pics
2 Attachment(s)
pics
get rid of the check valve and install a 90 or staright fitting,hook the existing hose that goes to the riser and run the water feed hose into the bottom of the manifold like shown in the pic..
http://www.cpperformance.com/detail.aspx?ID=2943 |
2 Attachment(s)
Call Gil and get hoses and hose barbs that takes out the tee on the manifolds. The hoses route the manifold water to the riser.
| All times are GMT -5. The time now is 01:06 PM. |
