-   -   Engine oil (https://www.offshoreonly.com/forums/general-q/229096-engine-oil.html)
ctbs99xc 04-25-2010 08:35 AM
Engine oil
Got a 85 wellcraft nova with a 5.7L what weight oil should I use in he motor? 20w-40 or 10w-30
jeffswav 04-25-2010 10:29 AM
Auto oil has removed a lot of the chemicals needed for the flat tappet cams. If you want a cheap oil try the Rotella diesel oil 15/40. If you want somthing better try Amsoil Marine/Diesel oil 15/40.
minxguy 04-26-2010 06:01 AM
Where are you buying 20w40?
Use a good motorcycle oil.
Tons of zinc.
Ken
