MSD Box w/ a Thunderbolt Distrib ????
Is it possible to use a MSD 6M box with a Thunderbolt distributor? If so , Is there a pigtail wire connector for it?
yes,tbolt 4 forsure,i never tiyed with tbolt 5.go to the msd website,it will show you how to wire it.
Originally Posted by mike tkach
(Post 3096448)
You do still need to run the tb4 module though..
kreed, i just did this a few weeks ago. the only prob is that u never really eliminate the factory ignition. the marine msd (6AM) wires through the factory module. i pulled it all out and ran a pro billet distributor and msd blaster coil. it made a world of difference at idle and bottom end. i also ran a 6A box that isnt compatible with the factory dist. i wanted to take out all the stock stuuf because of the problems i was having.
Originally Posted by xsboost525
(Post 3097027)
Fixx
you can use it with out the merc module..you have to rephase the rotor and run it as a locked out distributor with the msd,you use the distributor as a magnetic pickup..
Originally Posted by mrfixxall
(Post 3097040)
Fixx
Originally Posted by HaxbySpeed
(Post 3097135)
I've tried that before without any luck and I thought it was because the merc pick up is hall effect and not mag? It worked on an older 7 box on the dyno but wouln't trigger the 6m in the boat. Can you give a quick wiring diagram? thanks! Also for what it's worth the factory GM small cap distributors last a lot longer in a boat then the MSD. The MSD distributor's go green and the pick ups rust very quickly. On smaller blower motors I usually use the Voyager marine ignition kit ($350) it comes with new dist, coil with mount, and plug wires. It has about 8 degrees of advance in the module wich is great for blower stuff and has no problem sparking 800hp. It's also easy to run with MSD with a factory pigtail.. :drink:
if you take the white /red stripe wire and feed 12 v into it and connect the white/grn stripe i can get the distributor to trigger a signal to a dvom,,i haven't tried it yet on a 6 /7 al box yet,,i believe you could hook it up to the white point wire and it may trigger the box |
| All times are GMT -5. The time now is 05:05 PM. |
