-   -   Preload 1.7 Crane (https://www.offshoreonly.com/forums/general-q/229280-preload-1-7-crane.html)
glen george 04-27-2010 06:54 PM
Preload 1.7 Crane
After reading everything on OSO, internet and looking through my factroy manuals I still have a question. Adjusting the crane 1.7 rockers 1/2 turn down after valve lash and the pushrod seats down between .020 to .060, the rocker arms on the completely closed valves can be wiggled by hand just a tiny little bit. The engine runs better than ever and the valve train is quiet. When the intake valve and exhaust valve are CLOSED and and the lifter has bleed down and the only pressure on the pushrod is the preload, there is still a little play on the rocker only in the closed position. Is that normal?
mike tkach 04-27-2010 07:16 PM
yes,when the engine starts,the oil pressure comes up,wala,no noise.
glen george 04-27-2010 08:10 PM
I ran the engine and there was no valve train noise, I did removed the valve covers and hand checked each rocker in the closed valve position and could wiggle each one slightly.
BillK 04-27-2010 09:21 PM
glen,
That is completely normal with a hydraulic lifter.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Griff 04-28-2010 01:28 AM
Normal.
Jeff P31 04-28-2010 02:40 PM
Unlike most boaters that is normal. :drink:
glen george 04-28-2010 04:02 PM
thanks , glen george
