-   -   porpoising problems 24 superboat with twins (https://www.offshoreonly.com/forums/general-q/229623-porpoising-problems-24-superboat-twins.html)
superboatbrt 05-03-2010 10:28 AM
i recently bought a 24 superboat and have extreme porpoising poblems it will almost comeout ofthe water i have spun the motors in out up and down no real change
the boat has no planes 7f wde with a 24inch braket also prop selection dosent mater porpoises as so as on plane all the way up to 82 at which it gets white knucke scary almost jumping out of the water any help would be appreciated
Dave M 05-03-2010 11:33 AM
Call John at Superboat. He might give you some setup info.
BTW, I don't think he is too crazy about those twin OB 24's.
FIXX 05-03-2010 12:09 PM
Fixx
Try reversing the prop rotation...if the props are spinning inwards try reversing them by spinning them outwards..
ran into a problem with the same scenario with 4 blade propellers..don't know what your power is you you may have ot swap lowers or? drives or if outboards the engines..
wjb21ndtown 05-03-2010 07:28 PM
Sounds like you may need to install some k-planes
picca00 05-04-2010 07:56 PM
did you get the white and green one from freeport?
northernoffshore 05-04-2010 08:13 PM
the big ones.
