-   -   Water sender question (https://www.offshoreonly.com/forums/general-q/230111-water-sender-question.html)
BDiggity 05-09-2010 06:26 PM
What water sender goes in where a t-stat /crossover is located? Is it the water pressure or temp? I am assuming its temp but want to make sure. I noticed on my Hawk 525 the wire terminal on the sender just pulled right out.
Griff 05-10-2010 01:30 AM
The water temp sender and high water temp alarm are there.
Water pressure gauges are mechanical and use a small plastic tube that connects to the gauge.
BDiggity 05-10-2010 09:56 AM
i didnt think about the pressure gauges using the tubes. i had my dash apart & even saw them on the fuel & water pressure & speedo. :lolhit:
Thanks Griff!
Griff 05-10-2010 12:09 PM
Hopefully that is for your blower boost and not fuel pressure.
BDiggity 05-10-2010 12:40 PM
yeah, would have been. 2 were at the top of panel where my boost gauges are.
