-   -   Use big cam and big heads or procharger (https://www.offshoreonly.com/forums/general-q/230759-use-big-cam-big-heads-procharger.html)
endeavour32 05-22-2010 06:07 PM
Originally Posted by GPM (Post 3117193)
4.25 x 3.76
4.31 x 3.76
GPM 05-22-2010 06:28 PM
Originally Posted by endeavour32 (Post 3117194)
4.31 x 3.76
4.31 x 4.31 x 3.76 x .7854 x 8 = 438.8
B.O.T.E BBC427 05-23-2010 11:10 AM
how to contact rmbuilder
Can someone tell me a website or ph# for rmbuilder?
thanks!
FIXX 05-23-2010 02:09 PM
Fixx
thanks!
Bob 585-654-8553,, CAM AND PROCHARGER..
jeffswav 05-25-2010 07:00 PM
What is your HP and speed goal. I would see if a 4.25" crank could be used in your block. That would give you more torqe and HP. If you call Bob he would probably know. Definatly get your cam and matching parts from him.
Jeff P31 05-25-2010 08:35 PM
60 over 427 makes for real thin cylinder walls ! I used to run that combination years a go in my drag car, split lot's of cylinder walls . Not a good set up for a boat or a drag car !!!
TWO YOOTS 05-26-2010 06:07 PM
watch the cam
The procharger will give you excellent torque and hp throughout the rpm range but make sure you put in a roller cam. I had years of misery burning up two 454's with only roller rockers.I dont care what Procharger says you will burn up cams,lifters and pushrods even at 4lbs boost.
