MEFI help needed
I have a 2001 575SCi and did a total freshen this year. I also changed from the stock flat tappet hyd to a new hyd roller set up.
So now I am in need of some major tuning help. I am looking to borrow, rent, or buy (if I have to) something to make a new tune change. I also don't want to send my ECM out 15 times to get this right and risk melting valves again so I am going to install a wideband O2 sensor in the exhaust to do this with. So having said that, I also have some question. 1. How do I tie in the O2 sensor to whatever system is recommended to do the tune with. 2. How do I also tie in manifold pressure 3. and RPM 4. how do I set the timing (in base mode). 5. what connectors / cables are needed 6. and is there a system that can do this....... for a reasonable cost ........ because this is a one time event (hopefully) for me. |
You need Mefi Burn! Call and talk to Bob. He is a great guy and his software will do exactly what you are asking for. It will come with a data loging program and cable so you can watch all your engine parameters (MAP, RPM, Knock, Timing). You will need a separate hand held O2 meter like an innovate or fast unit. I have experienced the mail order tuning and it's a huge time sink and waste of dough, if you want it done right you will have to do it in the boat.
Good Luck, Jon |
Thanks Jon,
What about the ingition timing piece ? do i need a Merc scanner or can this jumper A&B to get to Basic Timinig mode?? thanks again |
jump A&B
I am not sure if the MefiBurn software will put it into base mode or not, it will allow you to read any trouble codes, if you have them. I had the merc plastic jumper cap, so I used that before I hooked up the software. All the cap does is jump A & B, a lot of people do that with a paper clip.
The software really is good, once you get a feel for it, you could get your boat dialed in a day. With out the software your hands are tied. It sucks getting your mefi fresh out of the mail box and within 5 min of hitting the lake put it back on the trailer because the tune is wrong. |
Originally Posted by Griswald
(Post 3114134)
jump A&B
got it ... thanks |
Originally Posted by DesertRage
(Post 3114137)
The software really is good, once you get a feel for it, you could get your boat dialed in a day. With out the software your hands are tied. It sucks getting your mefi fresh out of the mail box and within 5 min of hitting the lake put it back on the trailer because the tune is wrong. Ok --- Just talked to Bob at MEFIburn. He was tuning a boat as we spoke. Purchased the package plus an Innovate LM-2 Basic for O2. Bought the inductive pickup too for RPM. Should be good to go soon. thanks VP |
VP, That rocks! You'll have fun tuning now.
You have all the tools to dial it right in and if you make additional engine mods, you can compensate for that with a few table edits. The data logging program you will recieve will let you monitor and record TONS of engine parameters. Glad it worked out for ya! Jon |
