-   -   Intake gaskets (https://www.offshoreonly.com/forums/general-q/230916-intake-gaskets.html)
baja27 05-20-2010 10:36 AM
Intake gaskets
Which is the best intake gasket for a Gen 6 502 engine
Felpro or Mr Gasket
ballon78 05-20-2010 11:19 AM
Felpro or Mr Gasket
depends which intake...i bought both and looked to see which one matched up the best, went with the felpro 1211 i think, the marine felpro are stamped with the auto felpro number on them so they are the same they just use a marine number so u have to pay more. Ithink the 1211 didnt have the crossovers so that why i used them.
joepequa 05-20-2010 05:25 PM
cometic
BadDog 05-20-2010 09:29 PM
Really tough to beat the Merc HP500 gasket. It has some give to it so it will torque down and cover slight alignment issues.
Griff 05-21-2010 01:25 AM
I prefer the Felpro gaskets with the printoseal option.
ezstriper 05-21-2010 06:04 AM
I like the ultra seals from mr gasket
AIRFOIL292 07-22-2010 04:31 AM
felpro 1275s-3 for The Merlin Intake Square Port Heads.problem Sealing Around The Brass Insert With Others.salt Will Eat Around The Aluminum At The Water Ports And Develope A Leak Into The Lifter Valley.if You Get A Lot Of Milky Oil This Could Be The Problem.
