-   -   mercruiser mpi wont start (https://www.offshoreonly.com/forums/general-q/231091-mercruiser-mpi-wont-start.html)
jimmyjr 05-22-2010 11:00 PM
hi all,i have a problem with a 5.0 mpi merc its a 03 model.now here is the problem i put about 3 hrs on the boat and then ran out of fuel.i put fuel in and ran again for about an another 3 hrs.i put the boat away,and then went out today.ran for about 10 mins and it just died.i pulled the water sep fuel filter.and was full of milky substance.so changed the filter and now wont start.but will run with fuel sprayed down the intake.checked the pump and it is fine
.i need help
Boat Tech 05-23-2010 12:49 AM
.i need help
Take a look at this thread, It kind of sounds like the same thing.:eek:
http://www.offshoreonly.com/forums/g...urn-white.html
jimmyjr 05-23-2010 04:20 AM
thanks for the reply,how do i pressuirize the fuel system?
jimmyjr 05-24-2010 02:16 AM
ttt i realy need some help on this one thank you in advance
jimmyjr 05-24-2010 04:59 PM
ok i now have the white fuel gone.i then today tried to run the boat on an outboard tank and just couldnt get the engine to full power.it would run very rough and then start to backfire thruogh the intake i have lots of fuel pressure.fresh water seperator.but runs like its only running on five cyls,wont idle,and stalls while under load.i have had boats for years and i cant figure this one out.please any help is appreciated.
jimmyjr 05-24-2010 05:03 PM
also i dont expect someone to fix my boat over the computer.im in saskatchewan canada.and my local dealer has no clue what the problem is.he is a great guy just does mainly outboards up to 60 hp,mainly on pontoon boats.
jimmyjr 05-25-2010 12:07 AM
what is the procedure for cleaning the injectors i kinda need step by step.thanks
rchevelle71 05-25-2010 07:32 AM
Try running it off the outboard tank, with some seafoam mixed in, then let it sit, and try again.
jimmyjr 05-25-2010 09:49 AM
i dont think that i can get seafoam where i am at is there anything else that could be used?thank you very much for the reply.
Griff 05-26-2010 09:03 AM
Have you changed the spark plugs???? They could easily be fouled from the bad fuel.
