-   -   Oil leak on BBC (https://www.offshoreonly.com/forums/general-q/231146-oil-leak-bbc.html)
boatcrzy 05-23-2010 05:53 PM
Oil leak on BBC
Just got back from the lake. Been working the bugs out of the new Whipple BBC motor. I have a oil leak from the back of the engine. It drips down the bellhousing and into the bilge, Thought it was the rear intake manifold gasket, but I don't think so. I cleaned it all up and ran it , (ran it hard) and looks like I might have a leak around distributor and manifold. Anyone have any comments, or are there oil plugs up there that could be leaking??
Any toughts??? Thanks, Dave
tinman565 05-23-2010 06:37 PM
Was there a gasket installed on the distributor shaft when it was assembled ? Could also be the rear middle of the intake (between the heads..below the distributor). I'd start with the dist gasket first.
boatcrzy 05-23-2010 06:47 PM
oil leak on BBC
Timan,
Thanks for the reply. I don't think it is from the intake between the heads. I can see part of a gasket on one side of the distributor but not much on the other side. If part of the gasket got rolled under that could leak a good amount of oil, right?? Do they make an o-ring for that or would it have to have a grove to except the o-ring?
Thanks, dave
Smitty 05-23-2010 08:46 PM
There are 3 plugs above the crank and covered by the bell housing. There is oil pressure behind each plug. I have seen on some rebuilds where the shop replaced the plugs with new ones and they didn't seal up and you have a nice oil leak.
Bad news is the motor has to come out sine they are shrouded by the bell housing and flywheel.
Let us know what you find.
tinman565 05-24-2010 06:11 AM
Is the oil on the outside of the bellhousing...if it is...I'd say its coming from somewhere above. Keep wiping it down, looking, use a mirror if that helps...just keep searching. No o-ring for the dist that I know of...just a gasket. Wrap or stuff some paper towel tightly around the dist base....then run the motor. That should tell you if its coming from there or lower.
