502mpi Vapor Lock
I have a slightly built 502mpi that is getting vapor lock. It fires up great runs hard for about 1 mile and then starts vapor locking. I can unscrew the fuel filter a bit and tighten it back up and it's good to go until you shut it off for a while and does the same thing when you start back off. Any help????
vst tank or cool fuel?
vst ???
Isnt there a factory kit to stop the vapor lock issues?
clean the screens in the bottom of the vst tanks, and i run my bilge blower from the time i leave dock until i put boat away to help pump heat out of engine compartment. i also only run 93 octane.
the first thing i would do is get some decent ventalation thru the engine compartment... think about it... vapor lock occurs when the fuel gets hot enough to boil. that happens when the lines and intake manifold and all the rest get hot enough to cook on. if you get the engine compartment temps down not only will the motor run a lot better but your problem may well disappear
Originally Posted by SHAWN DAVIS
(Post 3126978)
It doesn't work with VST systems. |
Originally Posted by S.E of Disorder
(Post 3126969)
vst ???
(Post 3126978)
I don't think this is a vst, no square tank on top. The fuel filter is mounted on the left side facing the motor right behind the belt near the front and the lines run under the motor to the right side under the engine mount. What vents are they talking about being clogged. I can put the boat in drive about a mile and then it happens is that long enough for it to get hot enough? I can unscrew the fuel filter just a bit and tighten back up and its good to go until I shut it off for a while and then the same thing once I start back off again..
Originally Posted by sacaja
(Post 3127033)
| All times are GMT -5. The time now is 03:02 PM. |
