How much water presure is to much ?
what is optimum water pressure at idle through wide open I am seeing over 30 psi at 6000 rpm
ttt
30 is ok,,,but i say 17-25 is optimum !!!!!
Which engine is it and does it have a sea-strainer ??? |
It is a 598 na, no sea strainer and I am bleading off the pressure out of the back of the intake through 2 #10 lines into 1 #14 through the transom. Oh yeah imco lower and more like 35 psi over 100mph
35psi or more is starting to ask for problems. 20-25psi at WOT is about perfect. Idle usually barely reads anything on the gauge.
What should be my next move to try to reduce the psi
Originally Posted by Griff
(Post 3129101)
Originally Posted by Smoothsix
(Post 3129109)
Other way would be to stick a press relieve valve in the IN line at 25 PSI and dump it over board ! |
(Post 3129087)
I set up a temp gauge and had my passenger watch it we went 106 mph at 6300 rpm and he said the psi gauge hit 35 psi
| All times are GMT -5. The time now is 04:32 AM. |
