-   -   Baja 240 rpm question (https://www.offshoreonly.com/forums/general-q/232174-baja-240-rpm-question.html)
astar77350 06-08-2010 06:45 AM
i guess my main concern is why i can't get more out of the engine in the rpm range. If i switch to a 3 blade, will that increase the RPMs up almost 1000?
Rookie 06-08-2010 07:28 AM
Originally Posted by astar77350 (Post 3129675)
I just bought a 88 baja 240 sport, with a 454 mag. I am running a 4 blade prop, not sure the pitch but im sure its around the correct pitch for the boat (22-25) The boat runs 4100 rpm @ WOT. can't quite get to 60 mph. Does this sound normal for this boat?
You need to give the right information to get the right answer. What is the pitch of your prop? Make sure your tach is correct. If you don't know how can these guys give you the right answers. 3" of pitch could be a swing of almost 600RPM. One of my best friends has had 2 of these boats. The first had a 330 that did 58gps with a 21 Mirage+ and the other had a ZZ502 with a 22" Bravo1 that did 72. He now has a 557 and runs around 80 with ~630HP. It takes a lot of power to get these boats moving.
AIR TIME 06-08-2010 10:14 AM
thats cause of the x ,prop shafts are to deep a 2'' shortie will help on speed and handling will be better. also find out what size prop you have and if you have the mag which was 330hp in late 87, then came the 365hp mag in 88 and stock 330hp 454. that makes a different on which hp you have.
