-   -   What in a Holley carb would cause a mid range miss? (https://www.offshoreonly.com/forums/general-q/232372-what-holley-carb-would-cause-mid-range-miss.html)
whoya 06-09-2010 10:20 PM
I finally swapped carbs after changing everything out in the ignition trying to find a miss.
My Holley 850 Double Pumper causes a slight constant miss when running in the 3800-5000 rpm range.
What would cause a miss in that range? To much fuel dumping in some how?
Fuel pressure was set right and levels to.
ezstriper 06-10-2010 06:26 AM
you could be on the edge of the power valve opening, lean at that point then opens and you are good, what power valve are you running ? should be a 6.5 but that can change due to cam, intake, etc...are you running a vacume gauge ? they are very handy....
whoya 06-10-2010 08:34 AM
I tried a 6.5 and a 5.5 with same results. Im showing a vacuum between 10-14 it would not stay steady at idle.
fbc25el 06-10-2010 08:55 AM
Do you know what your fuel pressure is in that rpm range?
whoya 06-10-2010 09:26 AM
I have a gauge at the carb and put another one on (to check while running)with a line and its holding fuel pressure in that rpm range. I tried between 6 1/2 to 7/ 1/2PSI no difference.
Im about to go buy another Carb.
Tow-N-One 06-10-2010 09:50 AM
is the motor supercharged, if so you need a boost refrence carb
whoya 06-10-2010 09:52 AM
No, its a N/A 547CI
ezstriper 06-11-2010 05:52 AM
547 ci ? thats really taxing a 850, call patrick @ pro systems carbs, he set you strait !!! off the shelf carbs may not work well...Rob
