-   -   heads? cam? small block stroker build (https://www.offshoreonly.com/forums/general-q/232473-heads-cam-small-block-stroker-build.html)
zerotosixzero 06-13-2010 10:33 PM
You guys are super helpful. Ill make sure to research as much as I can I'm only doing this one time. If I want to go faster ill get a different boat. If I switch from alpha to bravo do I just need the drive or everything that's mounted to my transom. Can't get a bravo untill the following year so ill have to take it super easy on the alpha. Thanks for all the input thus far I feel like such a newb with my old school baja but its my first boat and a good one to learn with
rvtransport 06-14-2010 08:54 AM
mr fixall, that little donzi sounds great! Is it a 434 and what cam and compression are you running.
FIXX 06-14-2010 10:45 AM
Fixx
Thanx! BTW Sorry to steal your trend zerotosixzero :)
its a 355 cid :) compression is 10.3 and im running a comp cams xm270h.. i put it in @ 110*..i wanted a little more in the mid range and top end,,the boat come out of the hole like a scalded dog..mind you its all going through a volvo penta 280 drive, my props are volvo ultra's, 24 p L i spin up to 6200 rpms and my 26 with a heavy cup up to 5800 rpm's..
my next motor i want to build for it will be on the ls platform, im thinking a 413 cid out of a 6.0 but got to finish the formula first : )
Uncle Dave 06-14-2010 11:26 AM
Nice, what kind of actuation is it?
Mechanical, or hydraulic roller?
when you say 110*, are you referring to the lobe center?
UD
FIXX 06-14-2010 12:21 PM
Fixx
UD
Flat tappet hyd with hyd roller springs..110* LCA
Uncle Dave 06-26-2010 09:10 PM
5 Attachment(s)
Heres an update on my SBC project - got the engine back in.
Heading off for the lake tomorrow.
Uncle Dave
HaxbySpeed 06-27-2010 12:56 AM
1 Attachment(s)
I love seeing healthy small blocks. I like the 434 for NA apps. this one liked to rev a bit but has a Ton of hours on it and is still goin strong.
HaxbySpeed 06-27-2010 01:00 AM
1 Attachment(s)
I think this one will open..
Uncle Dave 06-27-2010 01:03 AM
You read my mind....
UD
Uncle Dave 06-27-2010 01:07 AM
Pretty nice....
Interestingly close to what I have as well- heads and all.
I see what you mean about rev happy- Must have sounded killer up there on the dyno!
I also see you started the pull at 4600. hows it idle?
Also I dont see the cam specs- can you share a bit more?
UD
