-   -   500 efi rough idle- surge (https://www.offshoreonly.com/forums/general-q/232691-500-efi-rough-idle-surge.html)
GoFastSonic 06-14-2010 07:07 PM
ok 2000 hp500 efi is idling rough sounds like on 4 cyl? also throttle is surging at idle sounds like gasping for air? I did notice plug wires look bad. Will replace them tomorrow had to order them. Any ideas? Bad sensor? Other motor running fine. Just did plugs checked cap and rotor. Im stumped
firehawkcat 06-14-2010 07:21 PM
New plug wires should make a big difference, I would do that first and see how it runs.
Airpacker 06-15-2010 12:14 PM
and make sure you put them back on the correct plugs. real easy to cross 5 and 7.
