-   -   Any idea where these wires go (https://www.offshoreonly.com/forums/general-q/232727-any-idea-where-these-wires-go.html)
qaberdeen 06-15-2010 07:54 AM
4 Attachment(s)
Having a problem with wondering if these wires need to be connected..
The first two pics are the drive Lube monitor and it has two wires coming from it..do they need to be connected and if so where..i went from an MPI engine to a carb, but the engine installer did not connect them
The other two wries r coming out of the transome plate, and they r not connected either..i'm figuring that one should connect to trim guage because i'm not getting a reading on the dash as far as where my drive is..the other ? and where to connect to ?
Thanks Q
Ted G 06-15-2010 08:11 AM
The 2 wires from the bottle hook up to the drive lube monitor on an injected and some carbed motors. If you don't have that hook up then don't worry about it, or you could hook up your own little light or buzzer if you'd like, the contacts close when the level gets low. The 4 wires coming from the transom are trim limit and trim gauge sender wires. The trim limit will be closed when the drive is down and open when you trim it way up. The gauge sender will have changing ohms across the wires as you move the drive, you should find the wires to plug in somewhere along the stringer unless your boat doesn't have limit or gauge.
qaberdeen 06-15-2010 09:05 AM
Thanks Ted, i guess i have to search around for the the wires, i guess once found, i'll try both to see which one moves the drive guage..
thanks again
Ted G 06-15-2010 10:30 AM
You're welcome. Is your 22 the red one that was bought from a guy in Maryland by the name of Mike?
qaberdeen 06-15-2010 01:38 PM
Yeah, i recently sold it though, regretting it everyday...
qaberdeen 06-15-2010 01:40 PM
that return wire, i should be able to trace it from the dash right..the one that will plug into the ones above coming out of the transome plate..
Ted G 06-15-2010 01:40 PM
LOL so is he :drink:
qaberdeen 06-15-2010 07:13 PM
Ted..I Know..lol
qaberdeen 01-22-2011 02:26 PM
Can anyone tell me where the the trim sender wires plug into, these r the two black wires coming thru the trasome.. when the engine was installed looks like these wires where overlooked..drive works great now just want the electric guage to work..i've looked up n down the engine wire harness but i don't c any loose wires..so just wondering where i can plug these wires
thanks
Q
FogduckerIII 01-22-2011 02:49 PM
thanks
Q
I "think" those plug into the trim pump solenoid....there should be bullet plugs off the trim pump that go to the bullet plugs coming through the gimal housing...???
I could be wrong, mine is set up like that though.
