trims wont work seperatly
this boat has dual engines..
we can make both trims go up seperatly but when we try to trim each motor down seperate they both want to go down at the same time?? we see on the one outdrive to trim sensor wires are broke apart would this be are problem. or wiring or the switches? |
Do you also have a switch that brings them up and down together? Like on the throttle?
have one trim button for each motor and 1 switch labeled trailer to raise them up all the way total of 3 switches.
i bought the boat like this.. also when u trim the motors all the way up they will go all the way to the trailer position. thats not suppose to happen thats what the trailer trim switch is for |
Does the trailer switch raise both motors if you press it?
yes trailer switch will raise both
