Livorsi Speedo, Garmin antenna
I'm having issues with my garmin antenna and livorsi speedo. The unit cycles as it should and then goes to the 9 o'clock position. can anyone tell me what wires you used. I've got the Garmin 17x reciever.
I think your SOL! I bought the same antenna for my livorsi data tach and it wouldn't hold a GPS lock. I called Fred at livorsi and he said there is a good chance that the garmin antennas are actually transmitting too much information and confusing the livorsi gauges. I purchased a livorsi antenna, hooked it up and everything worked fine! Good luck!
...Jim |
| All times are GMT -5. The time now is 11:52 PM. |
