-   -   One engine down on RPM at wot (https://www.offshoreonly.com/forums/general-q/233557-one-engine-down-rpm-wot.html)
MILD THUNDER 06-28-2010 09:22 AM
Just installed my motors in new boat. Borrowed some props from a buddy. Engines run in synch fine till about 5000rpm. Then the starboard engine will pull to 5500, while the port doesnt go over about 5100. The one thats low on rpm idles fine, sounds fine. No missing, bogging, or anything.
Im guessing a fuel supply problem? Tach issue? The props are in synch on his boat.
MILD THUNDER 06-28-2010 01:31 PM
Boat was sitting for 3-4 years. Fuel tanks were about empty. Just pulled my fuel filters which were new prior to this weekend, and there was alot of crud in them. I have the fram HP canister style filters, so there was alot of crud sitting in the bottom of the filter housing.
Wonder if that could be the issue. I may pull the tank pickups and see what they look like.
firehawkcat 06-28-2010 06:03 PM
if pick ups are dirty I would say that engine is starving for fuel hopefuly thats the problem
MILD THUNDER 06-28-2010 07:36 PM
I have 5/8" lines running from pickups to filters, then to 110GPH holley mech pumps. Then 8an line from pump to carb. I think im gonna pull the pickup and sending unit and see whats going on in there. I have a feeling its got some crud in the pickup tube...
Velocity Vector 06-28-2010 08:15 PM
I believe there is a screen in the pickup tube
offthefront 06-28-2010 08:24 PM
Careful at WOT ...dont lean that new motor out ....m
