-   -   drive swap info (https://www.offshoreonly.com/forums/general-q/233873-drive-swap-info.html)
ezstriper 07-02-2010 06:29 AM
drive swap info
I put this in drives section got nothing....whats involved with installing a newer bravo 1 on my 89 checkmate, is it a direct bolt on or ?? thanks Rob
hoozeyurdaddy 07-02-2010 07:19 AM
if it has a bravo now, it should be a direct replacement I believe.
but I think it has to be a X drive not a XR, I think there is a difference in the gimble bearing.
seafordguy 07-02-2010 07:53 AM
If you're just talking about bolting the drive onto the bellhousing then yes - no problem.
You can't bolt an XR onto a normal style Bravo Gimbal.
ezstriper 07-02-2010 09:14 AM
so the later model are a direct swap...thats what I wanted to know..now which are the best to try to run down ? thanks again..Rob
crapr6 07-02-2010 10:58 AM
Don't forget if its an older bravo gimbel with no self oiler set-up then a newer bravo drive will not just bolt up since the new bravo drives have the self oiler set-up and fitting on the drive that fits into the gimbel.
Erik
ezstriper 07-02-2010 11:05 AM
mine does have the remote oil resevoir, not sure if it was updated or came that way ?? thanks !
AIR TIME 07-04-2010 11:11 AM
go to a b1x drive , its got the steel tower worth the few extra bucks.
tony davis 07-04-2010 11:27 AM
Erm, yes you can!
