Blown Head Gasket After 2 hrs run time
No compression on cyl 4 and 6, pulled head, blown head gasket, and head is etched about 1/4 in down between both cyl. My engine builder is blaming the intake not being seated properly on the heads (of course he picks the part that I installed after he rebuilt the engine) and it sucked in extra air, leaning out the mixture and causing the gasket to blow...I am not convinced, as I diligently followed the proper torque sequence. When I stopped by the shop today, the guy who built motor was not there, but his other tech was showing me marks on the intake gasket, trying to prove to me the intake was either warped or not installed right. What raised red flag was he was showing me the odd # cyl banks, whereas it was cyl 4 and 6 were the ones that got hot and blew the gasket. If it was sucking that much air to cause a bad enough lean condition to blow a gasket, wouldn't I have heard and air sucking sound/backfires/etc??? The intake was an old 454 mag sq intake, former salt water boat, so I acknowledge its not perfect, but 2 hrs of runtime (nostly idling in the slip trying to figure out what was wrong) to blow a head gasket between 4 and 6 and then etch a hole in head???
I noticed the tech was re doing the studs in the head today when reinstalling the repaired/resurfaced head...Maybe some of the studs came loose or they didn't torque the heads down right the first time??? Given the intake sat on these same heads for years with no prob before makes me suspicious. would appreciate input. This is a 489 with 188 heads, cam from Bob Madara |
| All times are GMT -5. The time now is 05:10 PM. |
