bsebesy |
07-11-2010 05:09 PM |
Need help with an alpha I gen II drive
I have twin 5.7L mercs with alpha I gen II drives. Today the starboard engine started to slip bad. Normally when I idle both are around 900rpms, today the port was at 1100rpms. When I brought the boat up to plain the starboard rpms were 500-800 higher than they should be and hardly any power. The engine shifts ok and moves the boat forward (when only engaging the starboard engine) I figured it was a bad prop hub since I had one go bad earlier in the year(hit a stick), but I just pulled the prop and the hub looks good. Any thoughts?
