-   -   water in Valve cover and Cylinder #1 (https://www.offshoreonly.com/forums/general-q/234469-water-valve-cover-cylinder-1-a.html)
StarLoone 07-11-2010 06:20 PM
I found milk in my valve cover and PVC tube off my air intake manifold. I pulled all the plugs and found water in cylinder 1. So whats it gonna be? Air intake manifold or head gasket. The engine actually sounded good but the oil level is up even though, no water shows on the dip stick. Gonna pull the air intake tomorrow. All accesories are new, Manifold, risers and headers. Head gaskets were done but not sent to machine shop. I did over heat early in the season...
thanks
Dan
NOPUN 07-12-2010 09:58 AM
Loone, did you overheat after all the work? If so I would think maybe a warped head. Need to pull and have them checked by a machine shop.
The oil level rising without water concerns me . does it smell strongly of fuel? Over rich fuel system can cause fuel to enter crankcase resulting in many bad scenario's
Ted G 07-12-2010 10:08 AM
Oil floats on top of water, most likely a head gasket and water is deep in the sump.
NOPUN 07-12-2010 01:29 PM
Every time I've ever seen this ,it makes a chocolate milk,nasty,dirty looking fluid all over everything mess.
Panther 07-12-2010 02:32 PM
throwing this out there but how old are the heads?
StarLoone 07-13-2010 03:45 PM
Conclusion!!
IT was a broken Weld on a Heardin Cyclone Header that replaced my Gills. They were less than a year old.
Thanks for the feed back
Dan
90mphRAGE 07-13-2010 04:00 PM
I suspect the head is a bannana due to heat warping. I lost a hose to my sea pump 2 hrs after rebuild. Had to mill heads.
Good luck
StarLoone 07-18-2010 11:14 AM
Repaired the header, replaced the intake manifold and all appears well. I check for water religiously and caught this early which is how I saved the engine.
Danny
