Swivel shaft Specs
Does anyone know the specs on the inner threads of a bravo one swivel shaft. I need to chase the threads in order to get the tool that attaches to the slide hammer to tighten up, the threads are corroded, cant even get the tool started on the threads .The threads appear to be some sort of specisl cut Thank You
If you are reffering to the hinge pins, they ar 7/16 14 thread.
No i was referring to the threads for the swivel shaft removal tool but they to are 7/16 14 but thank you just the same
