-   -   496 water impellar (https://www.offshoreonly.com/forums/general-q/234910-496-water-impellar.html)
corydaugherty 07-17-2010 04:45 PM
496 water impellar
I changed my impellar because of low water pressure sensor going off, now I can't get any water to flow except for when I use my factory wash outs in the hull. I backflushed the engine several times with no luck. Everything was fine untill I replaced the impellar. Any ideas 496 mag h.o.
Smitty 07-18-2010 10:12 AM
Did you put the hoses back on the pump the same way they came off??? They might be reversed.
cubicinches 07-18-2010 11:11 AM
What condition was the pump housing and cover in? If they have any scoring, they won't prime or won't pump well. It's not uncommon, pump is a piss poor design... Brass housing with no wear sleeve or wear plates in the impeller cavity. Unfortunately, the usual fix is a whole new pump. Do a search on the subject, it's been discussed here plenty.
TWIN-SPINS 07-18-2010 04:14 PM
i would think you still have blockage from the outdrive to the raw water pump<<<
capt2130 07-18-2010 04:28 PM
If the top plate is wore. Lay it up on a disk sander and grind it smooth. That resolved my issue. Nothing you can really do with the bottom on the cavity of the pump. Unless you get a rebuild kit.
