Fuel Syestem Upgrade?
I AM RUNNING A GEN 6 502 WITH CANFIELD HEADS PUSHING AROUND 575 HP .IS THE STOCK FUEL PUMP AND FUEL FILTER OK WITH THIS SET UP OR DO I NEED TO UPGRADE TO HIGH VOLUME PUMP AND FILTER WITH BIGGER LINES??
here are two formulas for you to figure cfm requirements first, then gallons per hour required. i don't know what your stock pump puts out or i would have done it for you. i would still go about 10% higher to be on the safe side. Fran
required air CFM = engine cid X maximum rpm's _______________________ 3456 x volumetric efficiency required fuel flow in gallons per hour= air cfm x 4.38 x 0.08 ____________________________ 6lbs. per gallon |
| All times are GMT -5. The time now is 03:42 PM. |
